Anyone purchase Jackpot 2/1/2 stainless steel headpipe yet ?.
Since everything on the left side is OEM Harley components including the heat shield and crossover pipe, the left side is exactly the same as the stock exhaust and is basically an OEM subassembly. It sounds like you may have the shield installed too far back on the crossover pipe. We would be happy to help out if you give us a call at 877-729-4754
Below is a picture of these OEM parts installed on our heapipe
![](http://fuelmotousa.com/heatshield.jpg)
What size baffles do you have ?. Is it necessary for me to change maps in my PCV since I currently have 2" baffles and want to try out the 2.25". Will the sound be different if it's only a quarter of an inch in difference ?. What about the 2.5" ?. Please fill me in. Thanks.
Anyways, I got the baffles and Rush Mufflers from FuelMoto.
Thorey
Thorey
As for the map, Jamie said I can run the same map for both and he's correct, bike runs great with either.
Keep in mind if you change baffles back and forth as I do with my Jackpot tuned baffles they have a left and right. The right one has a smaller port. If you did not already know this I'd check your Rush mufflers if you buy different baffles. Good Luck!
Less restrictive than the '09 stock mufflers? Sure would appreciate it if you could let me know the part numbers stamped on your mufflers.
