Just got brackets welded on and now the fender is at the painter. I moved the fender down and back. I don't like the large space between the tire and fender. I used the Native Bagger weld in kit. I'm getting my spacers painted the same as the fender to help blend them in. Shaved of the rivets too. Also I took out the flares on the bottom rear of the fender.
After
Nice, but will you be able to remove the calipers when it's time for brakes without removing the fender? Just wondering if you took that inconsideration.
Tack fender in place and checked all the clerances. The calipers and with front suspenion bottomed out the regualtor clears fine. Thanks for the look out.
