Throttle progressivity - who has played with this??
Did you actually read my OP?
I did the same as you and it ran like crap, bogging down when trying to launch.
I suspect jimsreddyna is on the right track with the velocity being the reason it better to open it less at low revs.
But I still cant explain why a cabled bike doesnt bog down....
I'm not sure what he determined/discovered, but maybe he will chime in with an answer, or maybe you could PM him.
What you gotta remember about all TBW applications, even in cars and trucks, is that the ECU is in control, not you. When you twist the grip, the ECU sees you "requested" acceleration, then it checks all it's sensor inputs and opens the throttle only as fast and as far as it decides to based on the EPA driven map programed into it......It's all about emissions, my friend.
The aftermarket is making WOT override switches for certain cagers. When installed, they allow the TBW engines to fully respond when ordered to.
You cannot just max the progressivity without making other changes in the various tables to ensure that you get the fuel needed when the throttle is now open wider. You do not need bigger injectors, throttle body etc. It is all in the total tune. Anytime you change one thing, something else needds to be changed to either cope or offset what you did. You can make em run just fine.
There is no need for larger throttle body or injectors unless you go big bore and higher revs. Like the guy said, you can't just override the butterfly reaction without also doing same with injectors......The OP was playing with just one parameter.
How were they sychronized? Has your bike been dyno'd? The first thing to do when tuning a bike is sychronize these tables. You can't just change your cubic inches to 124 and be good to go. Then you can move on to the timing and other tables to tune. Adjusting any table (with exception of the clb tables if you are using "vtune" or "smart tune") before your ve tables are synched is a waste of time. As I mentioned earlier I was taught not to set throttle blade control table to max values in all the cells but to do it in a stepped pattern. Then after this was done and the bike was sill having issues with launching I would look at the accell enrichment table to remove or add fuel. Then if I removed fuel I would again check for knock retard as the accell table can also affect this. Like Dalton said " one thing affects another and it's all in the tune" .
The bike has been dynoed, I have not manually altered the VE tables but I have done some smart tuning at different throttle positions and it has worked wonders. Smart tune has never changed the values below 1500 tho..
It would seem unlikely that changing the throttle progressivity tables alone would result in the engine bogging you are describing, although it is certainly possible. Are you suggesting you made no other tuning changes in any other tables other than the throttle progressivity tables?
If the throttle progressivity tables alone resulted in the engine bogging, you might consider reducing the fuel delivery in the same same rpm range where the throttle progressivity was increased by modifying the VE tables to reduce fuel delivery (front and rear) in those same ranges.
Another alternative is to now run smarttune (assuming you are running the 2010 SEST) which will make the adjustments for you as you make data runs and store the data for use with SmartTune.
Other than these approaches to eliminate the engine bog, you'll need to go back to the factory throttle settings (you can get them from one of the other maps that came with the tuner software) and have an experienced tuner make the changes for you.
