more power from stock 103" 2010
Old 12-19-2009 | 04:46 PM
mgabr00's Avatar
mgabr00
Default more power from stock 103" 2010
Hi guys,
I have a 2010 electra glide ultra limited,and would like to get more power out of that engine without machinig.
any suggestions,Cams,Heads,etc, ?????
Thanks
Old 12-19-2009 | 04:49 PM
'05Train's Avatar
'05Train
If you want to keep it at 103 and not mess with anything, then a decent Stage One, A T-Man 590 cam, and a set of their Stage 2 heads would prolly do right well.
Old 12-19-2009 | 04:52 PM
mgabr00's Avatar
mgabr00
thanks
do you have any links for the list ?
Old 12-19-2009 | 05:08 PM
blown alcohol's Avatar
blown alcohol
If doing a head swap on the limited, wouldn't you need to use your current heads for porting. If you go with ported exchange heads you would need the heads drilled for the automatic compression releases. I am not sure if the head porter would have the fixture to drill the heads for the ACR.
Part#'s for the FLHTK heads are 17728-08 front, 17729-08 rear
http://www.tmanperformance.com/kits.htm
Old 12-19-2009 | 05:12 PM
mgabr00's Avatar
mgabr00
slow down alcohol
didn't understand half of what you said
if you have time ,explain it for the dummies
Old 12-19-2009 | 05:21 PM
mgabr00's Avatar
mgabr00
I found this at T-man
Stage 4 Thumper Series heads $1570
T-Man's TR662 cams
Forged 103" Pistons $405( machined to flat )
AIM Variable Pressure Clutch $445
is that a good combo ??????
Old 12-19-2009 | 05:23 PM
blown alcohol
If you exchange heads on your limited for a set of ported heads, you need to make sure they are drilled to accept the automatic compression releases. These come factory on the FLHTK limiteds.
Automatic Compression Release
Automatic Compression Release (ACR) valves reduce the strain of starting your high performance motor by reducing cylinder compression - automatically! The engine is easier to turn over resulting in less wear on your starter and battery. After start, the ACR valves close to restore full compression. ACR give you peace of mind and protects your investment. ACR can be installed on stock or Screamin' Eagle® Performance cylinder heads for all '07-later Twin Cam equipped models. Install requires machining to be performed by a competent machinisht using the Screamin' Eagle® Automatic Compression Release Fixture Kit P/N 94648-08 (sold separately). Installation requires separate purchase of model specific ACR Wiring Harness P/N 70623-06 or 70623-08.
28861-07A
Old 12-19-2009 | 06:04 PM
mgabr00's Avatar
mgabr00
thanks alcohol,very clear now,
will do as you said on monday
Old 12-19-2009 | 07:21 PM
Captain Itch's Avatar
Captain Itch
Sponsor
I run a 103 myself and may I suggest that you start out with a tuner,like what Fuelmotto sells,change out your air cleaner and a decent set of mufflers.If you have not done this so far it is the place to start,and that just may be enough for you..it was for me..
__________________
www.Captain-Itch.com
Old 12-19-2009 | 08:22 PM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
Former Sponsor
Originally Posted by mgabr00
Hi guys,
Thanks
How much power are you looking for?
10 hp gain
20 hp gain
30 hp gain
40 hp gain
50 hp gain
etc..
