Drain Plug
12-19-2009, 02:07 PM
Drain Plug
I am curious what the pipe plug next to the engine drain plug on a '09 model is holding back.
The manual states not to remove this plug, just kinda wondering what is behind it.
Anyone care to speculate?
12-19-2009, 02:09 PM
It's just a plug..you can take it out and install an oil temp sensor there if you like..
12-19-2009, 02:13 PM
Quote:
Originally Posted by
flhxkiller
So, is it just an opening to the oil tank?
12-19-2009, 02:16 PM
yep. they just don't want you to use it to drain the oil, believe its pipe threaded
12-19-2009, 02:21 PM
Check out photo "S". It is an oil pickup passage in the pan casting that directs the oil flow upward. It passes thru a secondary passageway in the transmission housing and from there the oil flow begins/repeats the oil flow circuit.
Like flhxkiller mentioned, many remove the plug and replace it with an oil temperature sensor unit.
Northbound Southerner
03-19-2012 11:03 AM
not2kool
11-07-2010 12:30 PM
HDSAE60
Oil Archive (no new posts)
08-12-2009 08:58 PM
VrodAJ
05-19-2007 09:22 AM
cutacroshorty
06-25-2006 01:49 AM
09 ,
2009 ,
bailey ,
cee ,
drain ,
engine ,
flhx ,
glide ,
harley ,
location ,
oil ,
plug ,
sensor ,
shield ,
street ,
temperature ,
transmisson
