lest muffler dripping water?
Old 12-19-2009 | 01:28 PM
Guntoter's Avatar
Guntoter
Like the second poster stated, tighten the clamp or loosen the clamp and push the muffler up (toward the front of the bike) on the pipe then retighten. May have to use a block of wood laid against the tail of the muffler and whap it with a plastic hammer to move the muffler. The moisture is just finding an easy route out of a small leak between the pipe and muffler. No secrets, invisible drain holes, conspiracies or Obamacare involved here.
Old 12-19-2009 | 01:36 PM
Sweetbaboo's Avatar
Sweetbaboo
Originally Posted by Guntoter
Like the second poster stated, tighten the clamp or loosen the clamp and push the muffler up (toward the front of the bike) on the pipe then re tighten. May have to use a block of wood laid against the tail of the muffler and whap it with a plastic hammer to move the muffler. The moisture is just finding an easy route out of a small leak between the pipe and muffler. No secrets, invisible drain holes, conspiracies or Obamacare involved here.
+1 That's what I did with my 09 EGC, just re-positioned the muff and re-tightened; end of leak.
Old 12-19-2009 | 02:09 PM
flhxkiller's Avatar
flhxkiller
like dion said, its just a byproduct of combustion, the EPA has these newer bikes running as clean as the cars..
Old 12-20-2009 | 10:19 AM
DocHarley's Avatar
DocHarley
If we look into the chemical make-up of gasoline we will notice that it is made of Carbon, Hydrogen and then requires oxygen to combust. After the reaction, the by products are Carbon Dioxide and water. After we balance the equation it will look something like this: 2 C8H18 + 25 O2 to 16 CO2 + 18 H2O. You will notice that the by product contains water. This is part of the reason it contains water. Most of this is vaporized because of the intense heat created during combustion. Depending on the type of exhaust system, the vapor may or may not condense on the inside of the exhaust pipes. This would lead to the appearance that it is dripping water which is normal.
Old 12-20-2009 | 10:39 AM
jimsreddyna's Avatar
jimsreddyna
It appears from the picture that the clamp is about 1/2" or more back from the end of the muffler inlet. It has been my experience that the clamps need to be at or damn close to the end of the muffler. If it is too far back, part of the clamp will be resting on a secion of the muffler inlet pipe that is not slotted and therefore cannot be compressed by the clamp to provide a seal.
Old 12-20-2009 | 11:11 AM
Sweetbaboo's Avatar
Sweetbaboo
+1 Exactly!
Old 12-20-2009 | 12:42 PM
Chainman's Avatar
Chainman
You probably have a cracked block letting water into the exhaust manifold.
Old 12-20-2009 | 12:48 PM
Classic Eagle's Avatar
Classic Eagle
My evo does that too. Usally after sitting a while mostly when its cold outside. Just condensation. When I start it, it drips out the end of the muffler and disapears when warm.
Old 12-20-2009 | 05:30 PM
flipbel's Avatar
flipbel
problem sloved
redid the clamp and done.
thanks
Old 12-20-2009 | 05:33 PM
flipbel's Avatar
flipbel
tnksy
Quick Reply: lest muffler dripping water?
