why did harley quit using the timken bearing after 2002
Old 12-19-2009, 08:49 PM
kingkingking's Avatar
kingkingking
kingkingking is offline
To save prodution time.
It isnt necessary when the 96 cube makes less torque than a cordless power drill. So they left it off.
Old 12-19-2009, 08:52 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Thats funny, they make more torque and horse power than any other stock Timkin bearing HD motor EVER did!
Old 12-20-2009, 06:28 AM
Northside's Avatar
Northside
Northside is offline
While I agree that the double Timkin tapered bearing setup is superior to the rollers now in use, the current set up is still more than adequate for stock and moderately modified motors. The weak point in the low end is the pressed together flywheel assembly. Your chances of flywheel scissoring is far greater than a bearing failure. By the way the "Timken" brand cam bearings aren't tapered, they are just the old Torrington bearing. Apples and oranges. Timken bought or merged with Torrington and they are branded Timken, there the similarity ends.
Old 12-20-2009, 06:45 AM
kingkingking
Thanks, it was meant to be funny...
Old 12-20-2009, 08:03 AM
Big Pig's Avatar
Big Pig
Big Pig is offline
Originally Posted by maineultraclassic
I was talking to a Timken Rep. last year about this, and he said it all came down to money. HD wanted the Timken bearings for next to nothing, and Timken refused to give them away............so they parted ways.
Steve
Unwise move on BOTH companies part if you ask me.
Old 01-03-2010, 03:01 PM
brogers's Avatar
brogers
brogers is offline
Does anyone know the build date when they made this change? I have an 03 softail but the build date is 9/02. I would love to know if it might be the old style
Old 01-03-2010, 03:40 PM
fxdwg_rugby's Avatar
fxdwg_rugby
fxdwg_rugby is offline
Default Greedy Basturds
Originally Posted by leohd
was always curious why they quit using the timken bearing in the motor after 2002? was it just being there greedy usual ornery bs or so robots could assemble the motors? doesn't make sense.
It makes sense, if you realize that corporate America are all greedy basturds!
I wouldn't purchase a new bike because they are built like crap and are not built to last!
Old 01-03-2010, 03:53 PM
fxdwg_rugby
Talking Here is $1.00
Thats why they build all the big torque and HP motors out of EVO bottom ends....LMAO
Go buy a clue...
Old 01-03-2010, 04:15 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
Its more a matter of assembly line proceedure than actual costs. It takes much longer to set precision end play than it does to stab a shft through a hole. Same reason for the chain drive cams as opposed to the gear drive set up from past motors. When production numbers go up in any manufacturing facility you have to find ways to do it quicker!
Time = Money. It's still a matter of them being cheap bastards. I would rather have a well built motor then one built on some bean counters assembly line.
mchj74
01-17-2015 08:03 PM
bagman1
02-15-2014 06:41 PM
rkoivisto
09-25-2011 08:47 PM
chadrosen78
Exhaust System Topics
03-17-2011 08:58 AM
driftbuster2
11-26-2007 09:49 PM
Quick Reply: why did harley quit using the timken bearing after 2002
