SE251 or SE255
Old 12-18-2009 | 08:03 PM
FLoTR's Avatar
FLoTR
Originally Posted by boogaloodude
+1 on that. You will get the idle you're looking for.
sorry guys, but that 204 is still not as much bump as I'm lookin for.
Twinrider's Avatar
Twinrider
This is the idle sound i'm looking for. Any cam suggestions?
http://www.youtube.com/watch?v=fvnZ6FFZcnU
Old 12-18-2009 | 08:07 PM
hog-doc's Avatar
hog-doc
You need a carbed Evo to get that sound. Twin cams, especially EFI TC's just wont get that sound, close but not exactly.
Its funny how HD motors have the same layout but all have thier own unique sound, Knucks, pans, shovels Evo's and TC's. You can pick em out blind folded.
Old 12-18-2009 | 08:09 PM
FLoTR's Avatar
FLoTR
ahhh, the EVO. Yeah, give me something like that. My wife's '04 883 sounds like twice the bike as my RG when they are beside each other idling.
Old 12-18-2009 | 08:23 PM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
Former Sponsor
Originally Posted by bwickes
The SE251 and SE211 will bolt in to your bike. I ran the SE251 with no head work on my 2007 for a while. It is now in another 2007 with no head work. That being said, you will not like the performance of either cam unless you bump the compression a bit. Big bore and a Cometic head gasket is the easiest way to get the compression you need to run either cam and keep the cost down. If you do that you will love either cam. The SE211 probably has the best sounding idle. You will get that bad *** race sound.
There are some other better cams, performance wise, if you leave it stock compression.
B
Just because you put 251 cams in your bike an it ran, does not make it right. Those cams require valve spring kit . Just because I can put 2 lbs of Sh*** in a 1 lbs bag doesnt mean the bag wont tare after while. Im sure your bike ran fine. But its not right. Your springs etc are not set right for those cams at a 580 lift. for stock heads. Not trying to fight with you.
And I am glad to see you picked tr/TMAN 590 cams great cams
That being said....
Specs from HD
This camshaft is a high lift version of the SE-211 camshaft.
As such, it works great with 103" and larger engines with free
flowing intake and exhaust. It can be used with stock heads
updated with race springs and high compression pistons to
get even more torque than a SE-211 cam or couple it with any
of the performance heads to realize the full power potential
of this cam.
For race application only.
25121-03
Old 12-18-2009 | 08:43 PM
FLoTR's Avatar
FLoTR
so what's the description for the 211's. How does it sound? Is this the most powerful cam for stock, free-flowing 96's?
Old 12-18-2009 | 09:43 PM
bwickes's Avatar
bwickes
Originally Posted by DRAGO'S BIKE WORKS
Just because you put 251 cams in your bike an it ran, does not make it right. Those cams require valve spring kit . Just because I can put 2 lbs of Sh*** in a 1 lbs bag doesnt mean the bag wont tare after while. Im sure your bike ran fine. But its not right. Your springs etc are not set right for those cames at a 580 lift. for stock heads. Not trying to fight with you.
Wrong, I put the TR-590 in after headwork. The SE251 was a great cam for the stock head set-up; about 10.1:1 compression, stock heads, 103", 99HP/102TQ, wide flat torque curve for over 10,000 miles and everything was in good shape when disassembled. Hit the rev limiter numerous times with no valve float at 6,200 RPM.
Give me some objective evidence why some Woods cams with more aggressive ramps and HQ cams with more lift are OK but the SE251 with .579" lift and less aggressive ramps are not OK?
B
Old 12-18-2009 | 10:26 PM
FLoTR's Avatar
FLoTR
another question, what is the compression on a stock 96 with good, strong cams
Old 12-18-2009 | 10:57 PM
DRAGO'S BIKE WORKS
Former Sponsor
Wrong, I put the TR-590 in after headwork. The SE251 was a great cam for that set-up; about 10.1:1 compression, stock heads, 103", 99HP/102TQ, wide flat torque curve for over 10,000 miles and everything was in good shape when disassembled. Hit the rev limiter numerous times with no valve float at 6,200 RPM.
B
Do you even know what valve spring requirements are?
When you make bikes that pump 500 plus horse come talk to me and tell me whats right.
As a shop owner I am going to recommend the best for your heads. I guess I should have said....
Yes the stock springs, seals and valves will work but it is recommend that you upgrade your springs for higher lift cams. on 570 lift and higher cams. As long as they have bee hive springs in them. Any one who makes cams and sells them and does head work will tell you to change the springs etc to match the high lift cams. I am not going to have a post war with you
And where was I wrong about your 590 lift cams I would never recommend that high of lift cam on stock springs, etc.. I said good choice on those cams.
Ride safe and have a merry xmas...
Old 12-19-2009 | 12:05 AM
DRAGO'S BIKE WORKS
Former Sponsor
spring height should be.
It is always recommaned that you check you spring pack before using a cam that is near your max.
1. put spring in vise and close it until the outer spring is soild
2. measure the spring land and note it on paper
3. now add up the installed spring height
( height=Soild height plus 0.60 plus max valve lift
4. max valve lift you can get from cam specs
5. when you get ready to instal them make sure you have a.050 minimum clearance between the top of the valve guide and bottom and upper spring collar at max cam lift.
6. Soild height + .lift refers to spring force when the valve is seated
I have been following this for a few years right from Andrews. I tried to remember this of my head to much sh*** to remember LOL I am not at the shop to look at my guides and notes.
