Cyclesmiths install question
There is a big green connector on the FBW that makes it hard to get it and switch housing wires both through, with the Cycle Smiths that are 1 1/4" its doable but there is a possability that the connector can seperate. Taping it real tight with electrical tape has proven to work just fine.
Harley has a extended wiring twist grip sensor (p/n 32310-08 $89.95) that does not have the connector and has the heated grip wiring extended also so its easier to add them later.
yup i did the same the green plug came out even after using super glue. so i had to take it apart and redo it the dealer told me to hard wire it thats what i did and it worked just fine . i also used the novello stretch it kit +12 for 16 in. apes on my streetglide iam sure there other ways but i tought this was good way it wont come apart anymore.
I did my apes when they first came out and at the time this was the only option
nowww Drag Specialties sales a nice plug and play extender for TBW
no more soldering you might wanna consider 16's though
IornStreetBob
02-05-2015 09:01 AM
