Headlight Bulbs!
You can't go by months or years. How many miles do you do in a year?
I think I read they only last like 300 hrs & that number is reduced if your like me and ride with high beam on in daylight. I'd like to find something better also but I guess it's a small price to pay for being seen in the daytime.
Mine don't last more than 18-24 mo. also.
I've used Hella 80/100W H4 bulbs for the past 14 years or so and have replaced them maybe three times in that period. You can find them here. The additional ~3A of current has not been a problem on my wiring or connectors. I don't know if the 55/60W (stock-spec) variety will give the same result, but normally the higher-output bulbs don't last as long, so I would expect the normal-wattage bulbs to last at least as long as the higher-output bulbs I've been using and probably longer.
For about the past six years I've been running a modulator on the headlight (high-beam only), which I've been told can prolong the life of the bulb. This is because it modulates at 20-100% 4X/sec. during daylight hours, and this reduces heat which kills bulbs.
This is OT, as the OP didn't ask about light output, but E-code (European) headlights provide a much-improved light pattern and "seeing distance" over the stock non-fluted headlights. I replaced mine with these Hella E-code headlights, which represented a great bang-for-the-buck upgrade at only about $33. I would estimate my "seeing distance" on high-beam is double that of the stock lenses, and the low-beam pattern provides a much broader area of coverage.
Been using PIAAs - I think I'm getting almost a full season off of them 15-20,000 miles. I know these things are going to give up on me so I carry a spare in the bag all the time.
I have my high beams on all the time - my observation is that driving lights help but the headlight provides the main attention-getter for turning and oncoming traffic. Have a look at oncoming bikes when you are on the road - you can easily tell those with high beams on and they stand out a lot more than low beams - particularly during the day.
I have run PIAA's in my last 3 bikes and have yet to have and issues with them. I have them in all 6 lights in my truck and had them in my last truck as well.
In the bike I run the anti-vibration H4. I had 22k on the one in my last bike. I use the extreme white plus that burns at 4K
http://www.piaa.com/Powersports/bulbs.html
Silverstar are automobile bulbs, not designed for vibration and shock from motorcycle use.
You need a motorcycle bulb like a PIAA motorcycle bulb that is made to withstand vibrations and shock. I had a set of PIAA bright white bulbs I used on two Harley's for over 4 years and 40,000 miles before I purchased my Goldwing. I plan to use them again if I am crazy enough to get another POS Harley.
DON'T TOUCH THE BULB, clean with alcohol before installing, as mentioned a single fingerprint can reduce the life considerably.
Steve
Steve
Lighten up a little!
I have passing lamps also , but you still can't beat a high beam Silverstar or PIAA lamp
someone experience with the
Extreme Xenon Super White H-4 Bulb, 60/55 Watt ,kuryakyn Partnr: 2222
http://www.kuryakyn.com/index.cfm/go/Home.ProductDetail/IMID/793
