Never thought it would happen!
Old 12-14-2009, 01:32 PM
piasspj's Avatar
piasspj
piasspj is offline
Originally Posted by bikes
The only thing I ever worried about while using my lift is, having it jacked up with the safety latch set and the hydraulic jack start leaking. Preventing it from being lifted up to release the latch stops and then to the ground. What would you do then?
The leak is usually slow so you should still be able to pump it up long enough to release the lock. Also if the locks are holding the weight there is almost no pressure on the fluid in the jack so it won't leak.
Old 12-14-2009, 02:10 PM
oinker02's Avatar
oinker02
oinker02 is offline
I'm guessing there was something on the floor that the sidestand hit when the bike eased down.....Maybe he'll decide to let us know why it fell right vice left.
Reminds me of last year when I had my truck on stands and my 15 year old floor jack decided to retire before I could set it back on the ground....It was late, raining and cold, only store open miles away.....Decided to ride bagger to work that night and borrow bottle jacks back(I had taken mine to work to use there)......That was a miserable long night......Bought two floor jacks the next day
Old 12-14-2009, 02:45 PM
Jrsess's Avatar
Jrsess
Jrsess is offline
Sorry to hear that! Bet you won't do that again!
Old 12-14-2009, 06:28 PM
Wally's Avatar
Wally
Wally is offline
The lock on mine will and has failed. Luckily the hydrolics had not bled down much further, but I'm always nervous of leaving the bike on the lift for long.
I have a 16" or so , piece of 6 x 6. I slip it into the jack, then let the lift down so it squeazes the wood and won't drop any further.
I leave it like that sometimes for months, sometimes for hours, no worries.
Old 12-14-2009, 06:37 PM
Maxcustody's Avatar
Maxcustody
Maxcustody is offline
Sorry, but good info, I just checked mine after this post.
Old 12-14-2009, 07:14 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
The jiffy was down and nothing under it.As it is, I have to lift the jack and shove it in place to get it under the left bottom rail.I think the jack prevented the bike from falling onto the jiffy stand.
Would have been a lot worse if the jack handle went into the side of the tank.I was lucky!
Old 12-14-2009, 07:28 PM
UltraKla$$ic's Avatar
UltraKla$$ic
UltraKla$$ic is offline
Old 12-14-2009, 08:03 PM
Suede Blue Man's Avatar
Suede Blue Man
Suede Blue Man is offline
Originally Posted by Texas Fat Boy
What all these guys said. \/
Yep, what TFB said.
Old 12-14-2009, 08:32 PM
lp's Avatar
lp
lp is offline
Received 2,856 Likes on 1,602 Posts
I have a sawed off 4x4 that I stick between the jack just to combat this. My Sears Red leaks down, the Yellow..not yet.
lp
Old 12-14-2009, 09:34 PM
2003Springer's Avatar
2003Springer
2003Springer is offline
man Thats bad but If you had called and bought the beer would have helped you buff it out
Quick Reply: Never thought it would happen!
