Dakota Digital
Old 12-11-2009, 07:42 AM
StreetGliderRider's Avatar
StreetGliderRider
StreetGliderRider is offline
Default Dakota Digital
I'm just wrapping up my DD install, can anyone tell me if these gauges are really plug and play or is there going to be alot of calibrating. Need some info before I connect battery. Thanks
And a very big thanks to Dawg for the bracket part numbers
Old 12-11-2009, 09:17 AM
FLHTCU Owner's Avatar
FLHTCU Owner
FLHTCU Owner is offline
I don't have the DD's, but have looked closely at them and am pretty sure there's no calibration necessary - with the exception of the odometer, which can only be done by Dakota. In other words, they can set the odometer mileage to what your mileage is now so that it matches. Otherwise, keep the stock gauge for 'proof' of when you changed it.
Here's the wording from DD:
MCL-3006-OT is a complete 6 gauge set that plugs directly into your stock wiring, and even use the stock mounting hardware and senders*. Fits all 04’-UP Harley-Davidson fairing models including Road Glide.
Old 12-11-2009, 06:58 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
wcsj55@yahoo.com is offline
I think you have to calibrate the speedo,a friend of mine used his GPS!!!
Old 12-11-2009, 08:31 PM
YtseJam's Avatar
YtseJam
YtseJam is offline
The plug and play only pertains to the wiring, you will have to calibrate the fuel, tach, speedo, and oil pressure. The rear cyl temp and the volts are good to go, assuming you bought the 6 gauge kit....
Old 12-11-2009, 09:31 PM
StreetGliderRider
OK here it is... the current milage on your anolog speedo can be set by you but has to be done within the first 100 miles - I've done it
08 and up you must change the setting for your fuel gauge.
Your gear indicator must be set while you ride and shift.
Everything else is ready to go, tech help at DD walked me through it, great people.
Now, I can't wait to get it out on the road.
Old 12-11-2009, 09:35 PM
YtseJam's Avatar
YtseJam
YtseJam is offline
I had a lot of trouble with interference and the speedo...finally got it fixed, and your right about the tech support, great people!
Old 12-11-2009, 09:54 PM
StreetGliderRider
what kind of interference and what was wrong with the speedo. something DD could help with.
Old 12-11-2009, 10:08 PM
YtseJam's Avatar
YtseJam
YtseJam is offline
The speedo was picking up signal from the ignition which caused it to sporatically pick up the RPM. I would be at an idle, and the speedo was showing I was going 20 mph. My gauges are gen 1, so I had to hard wire them in. I changed the positive source, tried to seperate the wiring looms, checked the plug wires....nothing helped, even they ran out of ideas. We were to the point of replacing the gauge itself. I finally tried swapping the black wires coming from the bike, which were not labeled, and fixed it.
I must have called them once a day for a week after trying the latest suggestion....always patient and helpful. I gave them a run for their money!
Old 12-11-2009, 10:13 PM
stevelonewolf's Avatar
stevelonewolf
stevelonewolf is offline
Calibrated mine. Easy to do.
Old 12-11-2009, 10:32 PM
StreetGliderRider
great to see you got them working
Quick Reply: Dakota Digital
