SE Compensator Questions
Old 12-17-2009 | 09:13 AM
tenn.vol.'s Avatar
tenn.vol.
Well lets be PC and call them cheep-cheep, JUNK is too harsh!
Lets group them (comp) with the PAPER base gaskets and inner
cam bearings. Of both which I have had to replaced, and a SE
comp in the garage. Or we could call an ace an ace and a......
Tenn.Vol.
  #42
Old 12-17-2009 | 10:44 AM
iclick's Avatar
iclick
I replaced my stock comp to the SE about three months ago, not because I was having trouble but because I had the primary completely disassembled to replace a faulty mainstaft bearing. The opportunity was there so I went for the gusto. I was having no trouble with the stocker except the starter clunk, which never bothered me much and after a while I didn't even notice it. After replacing it the clunk is gone and shifting seems to be a bit smoother, but other than that I can't tell much difference. I do not do hole-shots or otherwise abuse my drivetrain, so I'm sure there are advantages to this SE comp that I haven't sensed in my application and riding style.
Would I have done this upgrade had I not had the opportunity to do so without any extra labor involved? Probably not, as I wasn't really having any problems with the stocker. Looking at it at 32k miles reveals little wear, so I have no evidence to suggest that it would have given me problems in the long-run. My recommendation is that you should replace it with the SE comp only if you plan on doing some major engine work that might overwhelm the capacity of the stock comp, or you are having issues with the stocker that you feel will be rectified by a swap. My 2¢.
  #43
Old 12-17-2009 | 11:30 AM
sniper77's Avatar
sniper77
Look how many high output cycles use belts drive primaries, they seem to do pretty good without any comp whatsoever....
heavypic
13
06-14-2021 05:53 AM
lwowings
2014-2023 Touring Models
11
12-13-2015 03:31 AM
nighttrain72970
03-11-2015 05:27 AM
lunyty1
07-13-2010 09:11 AM
ANIMAL03
01-06-2010 02:09 PM
Quick Reply: SE Compensator Questions
