SE Compensator Questions
Here is a link with photos and will help alot for the DIY.
https://www.hdforums.com/forum/testi...mpensator.html
I have been looking and researching about a knock that I have on initial startup. I had the problem several months ago and the dealer couldn't find the reason, but blamed it on a loose comp bolt. They said they torqued it back down and here I am a few months later with the same knocking. Any way I could get a dealer to install a the SE compensator for the fix, or is there anything they can to to fix it otherwise?
JUNK, realy? Is that based on the HUGE number of them that you have seen fail? Or is it a personal opinion based on the fact the SE gearing is better for the way you like to ride and realy has NOTHING to do with the COMP at all?
I was just coming in this thread to ask the same question. I have the IDS and was wondering if anybody that did the SE Comp mod took off the IDS if they had clatter like before?
lp
Hey thanks but Iam not new to the site or HD's. Iam a Master Tech at a large dealership, have had over 5000 bikes on my lifts and have seen 1 comp failure and it was due to wear, 50,000+ miles. Hundreds of loose comp nuts but if you reinstall it properly it wont come loose again.
I agree its JUNK. I have 4 Harleys, 9 other bikes.
It is pitiful HD would put something so crappy on a bike, when they already know its junk, and have a replacement.
Will the stock unit break? Maybe (probably) not. Will it bang on start up, and degrade the take off? YES
Does the bike cost more than $10K?
That defines "junk" to me.
JMHO....I am not a mechanic, just a customer. Not trying to give you a bunch of crap, but jeez...just because it don't break don't make it good.
This compensator doesn't change the gearing...it's 34 teeth, same as stock. Any other rocket science questions? Most Master Techs learned that on day two or three.
