Do I need an amp?
Old 12-09-2009 | 08:45 PM
krazy3's Avatar
krazy3
I find on my '07 SG that a CD is much easier to hear than the radio. I have no idea why.
Old 12-09-2009 | 08:58 PM
wolfman 66's Avatar
wolfman 66
I wear a full face have jackpot mufflers. I have a set of polk mm651 speakers no amp i can hear it fine up to about 75mph. cbailey 8in shield
Old 12-09-2009 | 09:56 PM
gregbenner's Avatar
gregbenner
Dave, I totally mis typed. I meant earbuds of some sort to transmit the music. I have several friend who do this, ans swear by it.
Originally Posted by deeve
I do think reducing the buffeting would help somewhat. I should have mentioned, when I do ride on the highway I wear earplugs too....which wouldnt help hearing the stereo sound any I dont think...
Dave
Old 12-09-2009 | 11:25 PM
onthelo's Avatar
onthelo
$300 won't get you much.. I recommend a 2 channel arc amp a set of 6 1/2" speakers with adapters and you will be rockin no problem hearing it from stock to that you can't even compare! Prolly gonna run ya about $700 though but well worth every penny imo..
Old 12-09-2009 | 11:30 PM
deeve's Avatar
deeve
Good info everyone. The J&M's sound like a decent speaker setup. Any problems with getting this now and amping later? I suppose I could also go with the Hogtunes and amp later with their kit or any amp for that matter. At least speakers will get me halfway there and who knows, I may be happy.
Anyway again, thank you all for the great advice!!
Old 12-10-2009 | 12:01 AM
HardyHarHarley's Avatar
HardyHarHarley
Try the Biketronics 6 1/2 inch Titan Speakers with their 75 watt amp. That combo is more in a "reasonable" price range. That's what I run and can hear the audio pretty good at hiway speeds. I have D&D Boss 2 into 1 exhaust and they are very, very loud. Windshield is the Klockworks 6 1/2 inch. No buffeting.
I also have the tramsparent vent louvers on the lower edge of the fairing and they do a good job of reducing wind coming up around under the fairing.
Hope this helps.
Jim
Old 12-10-2009 | 12:52 AM
PaFatboy's Avatar
PaFatboy
I had a Harley Salesman telling me that the NEW HD speakers are comparable to the competition's speakers. He suggested I go back and listen to a pair on a SG. He claims that they are 25% louder at the same setting as the stock ones. I think they were $75 a pair, sounded too cheap to me.
Old 12-10-2009 | 06:27 AM
MACHD03's Avatar
MACHD03
Default Amp
I woud research the amps and the spec's on them, nothing wrong with hogtunes, I have one, but if you look at the specs, there are amps out there that put out more power and not much more expensive.
Mac
Old 12-10-2009 | 08:34 AM
HDV-GLIDE's Avatar
HDV-GLIDE
09 SG with a 7" half moon shield with the side extensions, Hog Tune Speakers and Tweeter Pod. I only use satellite radio or an I-Pod. The volume is great and the vocals are clear without an amp. I think the extensions on the windshield are a big factor. I thought about an amp but I'm very happy with the sound now and think an amp would be overkill for me.
Old 12-10-2009 | 08:40 AM
lkr0's Avatar
lkr0
]totally agree with this [QUOTE=MACHD03;5948951--"I woud research the amps and the spec's on them, nothing wrong with hogtunes, I have one, but if you look at the specs, there are amps out there that put out more power and not much more expensive. "
Mac[/QUOTE]
