Trailer Ramp Door Weight Limit
I have a 6 X 12 Carry On Cargo trailer with a ramp door. I have used it for a couple of years to transport a Heritage Classic with no problems.
I now own an Ultra Limited weighing around 900 lbs. which is approximately 200 more than the Heritage.
The trailer manufacturer says the weight limit on the ramp is 1000 lbs. which is pretty much standard on all trailers. Riding the Ultra Limited into the trailer exceeds the weight limit (bike + rider).
I have not yet used the trailer to transport my bike, but a friend used the trailer to transport an Ultra Classic and there appeared to be no problem, but I don't know how many times the door will hold up to the weight of the touring bikes + rider.
If any of you have encountered the same problem what did you do? Did you "beef-up" the door? And if so, how?
I know there will be questions about trailering any motorcycle, especially a touring bike, but that has all been discussed on this forum many times.
Thanks
Thanks
The door on my hauler is rated at 1000# per axle. By the time the rear axle is on the ramp, the front is nearly off. There is no where near the 1000# in the center of the ramp at any time. I don't believe you will have a problem, unless you try something like someone else mentioned and load two at a time.
