Want To Go From 16" to 18" Wheel
Old 12-04-2009, 04:28 PM
1sweetglide08's Avatar
1sweetglide08
1sweetglide08 is offline
Default Want To Go From 16" to 18" Wheel
I went through the serach section and tried to find out how a 2010 StreetGlide wheel would fit on a 2008 StreetGlide. I like the look of the 2010 wheels and want to know if anyone has made the change yet? If so what will I have to do for it to fit, will I have any riding effects from the different tire threads on a 08 to a 2010? I have 6200 miles on my front wheel and the wheel I'm buying has about 1500 miles on it. Any help will be helpful...such as how it will ride and handle, speedometer difference, rotor, bearing,ABS and will it void my warranty? I have ABS on my 08.
Old 12-04-2009, 05:19 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Thumbs up
I am awaiting any replies as I also am very interested in the very same swap and I have ABS too!
Old 12-04-2009, 05:51 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
As long as the 2010 bike your are getting the front wheel from has ABS also then the wheel will fit. You will also be able to use your brake rotors. The new Dunlop 130/70-18 tire has a diameter of 25.32" and your stock Dunlop MT90-16 tire has a diameter of 25.30". So basically everything is the same size but you have more wheel and less sidewall. You might feel a little more of the road but the bike will still handle well. Your speedo won't be affected enough to matter. If you like the look of the 18" then go for it.
32roadking
Touring Parts
03-10-2012 12:23 PM
swaite
07-21-2010 08:20 AM
vickon
04-26-2010 08:53 PM
kildar
Touring Parts
12-16-2009 06:59 PM
Quick Reply: Want To Go From 16" to 18" Wheel
