Where is Tunning your Suspension Link???
Pick a spot that you can measure vertically to get a starting point for bike with no weight on it. I used the top shock bolt, to the ground. Jack your bike up till the wheels are barely touching the ground and measure from your point(top shock bolt), to the ground. Then take the jack away and measure again. The "free sag (measurement w/o you on it), should be somewhere around 5-10mm (1/2" will be around 12mm), then have someone measure the bike with you sitting on it with normal riding gear on. The sag (difference in measurement from bike on jack) should be around- 25-35mm (1- 1 1/4"). If you don't have at least 1" of ride sag, you are missing out on a better ride than you have. To adjust the sag, break loose the 2- spanner nuts and turn spring counter clockwise (from top), making sure that the bottom spanner nut is turning with the spring, until you get at least 1" and up to 1-1/4". Hope that helps. **make sure that you lock down the spanner nuts together, once you get the sag set. It makes alot of difference, take the time and do it, trust me....
not sure about a link....but here's a post how to set shock sag.
Those are good sag measurements and it is used for setting spring rate (# or Nm of spring force). unfortunately this great method of measurement is lost on a bike that for the most part can not be tuned. Adding air to your rear shocks adds spring pre-load only. Problem is the shocks are not at all fair quality. The front forks can be tuned also by purchasing a set of good springs and than measuring the sag #'s than adjusting the pre-load spacers you must add. The stock progressively wound springs in the latter model FL's do not use pre-load spacers.
The oil thing and lots of other work to change the bike will only yield minimal results. For the time spent screwing with it yo would be better off getting a second job flipping burgers until you saved enough money to purchase quality suspension. You would be further ahead as your time is worth something to you.
stock touring suspension = air shocks....no real way to adjust the sag. Fastharley is right about quality suspension....our harley's come with just OK suspension.
Spring Pre-load
Even with emulators and linear rate springs (I do not use progressively wound springs as a rule) you will gain an improvement but unless you go with some kind of cartridge system, the results will not be near the same. Sorry, that is just the way it is. When setting up your font end look for riders sag to be around 1 1/4" ~ 1 1/2" measured stroke. Thats the best you can do for yourself using a conventional HD fork/internals. Measure from bottom of triple tree to center of the axle. Keep cutting the pre-load spacer untill desired measurement is achieved.
XPress
2014-2023 Touring Models
19
04-25-2024 06:49 AM
