Progressive fork cartridges..
Knowing enough about suspension, I would have to agree with you. A progressive spring is kinda like a bandade for setting up your suspension correctly. I know that I hated the way my bike handled with the progressive 430 shocks on it. I bought a pair of Ohlins from Howard and they work amazing.
I have the fully adjustable Ohlins on the rear of my Dyna. List was $1500, got them for just under a $1000. The "good" Ohlin front fork stuff will be more than that. They are tremendous shocks, and I hope to get some Ohlins (from Howard) in the front....trouble is they will likely cost more than the rear shocks. Note that the Dyna (an 07) was FAR worse than the RG, I mean really bad.
I totally agree the the adjustable Ohlins are better than Progressive or Works. For me, the issue is whether you want to spend over $2000 (plus labor if you can't do it yourself).
Btw, Works uses linear wound springs, not progressively wound.
After Mark Parnes tries the Works, assuming they help, I will try the Works in my 07Road Glide. Just not interested in spending $2-3k on the RG.
Marc has an 09, I have an 07 (both RGs). His front suspension is clearly better than mine, less dive due to stronger springs, but neither are world class by any measure.
Hopefully we can post the results in a couple weeks or less.
greg
greg
Two grand!!
That changes my thinking completely.
As much as I would like to try the much touted Ohlin's, or even Works, shocks and front springs, that price puts me out of the running by at least 15 hundred. Too bad really. They sound like some good products.
Never can tell though; I might get a serious windfall someday and if that happens I'll be having these products in the back of my mind.
Till then I'll be looking at Progressive's like most folks.
Two grand!!
Do it once, do it right. Save up for the best. For a few hundred more buy new lowers and tubes, put the ohlins in them and keep your standard forks in the shed. when you sell the bike put the stock legs back on and keep your ohlins for your next bike. Fully rebuildable, so when they wear out you can make them as new again whereas your progressives are trash.
It is hard to justify the $$$, but I stopped trying to justify the money I have spent on my tractor a long time ago. I forgot what my engine cost the first time I gave her a big fistful and she nearly pulled my arms out of their sockets. You will forget what your ohlins cost the first time you hit a big bump mid corner with a board dragging and she doesnt try to throw you down the road...
