veering left
Old 07-13-2006, 10:40 PM
nb472's Avatar
nb472
nb472 is offline
Default veering left
Wondering if anyone else has experieced this. At highway speeds my 02 RKC wants to veer to the left if I remove my hands from the bars. Is this normal or do I have a alignment problem.
Old 07-13-2006, 10:46 PM
Edmo's Avatar
Edmo
Edmo is offline
Default RE: veering left
My '06 RK Classic does it too... If I lean right I can get it to run straight...
Edmo
Old 07-13-2006, 10:55 PM
nb472's Avatar
nb472
nb472 is offline
Thanks Edmo, thing is while cruising with one hand on bar I must apply slight rear pressure on left bar and slight forward pressure on right bar. Much prefer left bar. No big deal, but I thought I'd ask someone else. Thanks
Old 07-13-2006, 11:05 PM
Edmo's Avatar
Edmo
Edmo is offline
My turn is ever so slight, but it's there. Being it is an '06 with only 850 miles on it I would think it is as close to "factory specs" as you can get... I guess the roads in Wisconsin all turn slightly to the left.
Edmo
Old 07-13-2006, 11:49 PM
howieheels's Avatar
howieheels
howieheels is offline
same here, a little turn to the left
Old 07-13-2006, 11:51 PM
blk06rk's Avatar
blk06rk
blk06rk is offline
My 06rkc does it to. Wish I knew why?
Old 07-13-2006, 11:59 PM
jlacasci's Avatar
jlacasci
jlacasci is offline
I have an 05 Ultra, when I first got her I tried out all the features including cruise control. Down the highway no hands she was dead straight. I was surprised at how dead on she was. This year, she pulls to the left. Not enough to notice while holding her, but let go of the bars and she goes left. I did add highway pegs, and slighltly adjusting my passing lamps to point out a bit. I thought that perhaps it was wind resistance between the two changes being off a bit??? Am I nuts to think this could be it?
Joe
Old 07-14-2006, 12:51 AM
RED E GLIDE's Avatar
RED E GLIDE
RED E GLIDE is offline
My theory is they drift left due to the extra weight of the clutch, primary chain, and the compensator. Ride a bike that doesn't drift, lean
a little to the left and it will drift won't it. I thought they all drift left!
Old 07-14-2006, 01:02 AM
BigGeorge's Avatar
BigGeorge
BigGeorge is offline
I have a street glide that runs straight as an arrow down the highway. If your motorcycle is an "02" I would suspect at some point in time the rear tire or belt was changed or adjusted and my be out of alignment but on an "06" bike I would think it should run straight from the factory and if not the dealer should be aware of it and make an attempt to correct it...........BG
Old 07-14-2006, 02:03 AM
MOking's Avatar
MOking
MOking is offline
search on alignment or "pulls to the left" on the touring forum. you will find a ton of other complaints with pages and pages of issues.
Quick Reply: veering left
