Covering bike in garage?
Comforter would be good in case something hits the bike it would protect it.King size sheet will keep the dust and fade off the bike.I use blue and silver cheapy and it has been great.I have centerstand that takes weight off the tires as well as the bike taking up less room,
Have the black cotton cover for indoors. Store in an unheated garage in MN. Never had any rust on either my '03 RKC nor my '07 Ultra. Winterize the bike and have put it on a lift to get the tires up... don't know if I really need to do that though.
I have a cheap light weight that I sometimes use on trips to keep condensation or rain off when outside. I like the idea of using the cotton (used a sheet until I got the HD cover for Christmas couple of years ago.) that breathes for an extended storage.
You said you bought your bike used. Did it already have rust? It's possible it was ridden during the winter after they salted the roads. You can get salt in a lot of places when you ride on those roads and that can lead to rust/corrosion.
I cover the Ironhead with an old bedspread. I cover the RKC with a HD cover that is now obsolete. It is cotton canvas on the outside, but has fake sheepskin on the inside with aluminumized heatshielding on the inside bottom. It likely weighs 15lbs. Both do a great job of protecting the bike from dings/scratches....Cover my car, too, with a custom fit cover that is pretty thick.
Sounds good, I'll put the cover on and call it good. I also purchased a HD battery tender and since my bike was already pre-wired, it was an easy hook-up. All fluids were changed so I should be good to go. Just wish Winter here wasn't so long - I just bought the bike two weeks ago and didn't get much of a chance to drive it yet. All it needs for Spring is a new windshield and more comfortable seat for the wife.
