O.K. I give up! What's the trick?
Am trying to put new front pads in my 08 RK. I have done brakes many times before but not on my RK. Have read all the "hints" in the forum and also in the factory manual. I did the shoelace cleaning routine for the pistons but now no matter what I try I can't get the outboard piston to retract enough to clear the rotor with the new pads installed. I have tried opening the bleeder on the caliper to release the pressure but still "no go". Anything I am missing? I even tried putting the old pads back in and using them as a fulcrum while prying in the gap with a large screwdriver. The piston will not retract. Any ideas?
I use two wide putty knives that I've sharpened on my bench grinder so that the blades will slip right in. If you have problems on just the front, just pull the entire caliper off and it's much easier to do. I feel your pain cause I've been there before. Patience is a virtue. Try taking the lid off of the front master cylinder.
I have seen Howard's write-up before but it does not deal with "how to retract the pistons" after you compress the brakes to do the cleaning. The pistons simply will not retract no matter what I have tried. The only thing left for me to try is to dismantel the entire caliper and see what is preventing the retraction.
