Notices
Flickering red tail lights
Old 12-01-2009, 09:46 AM
FLAGS's Avatar
FLAGS
FLAGS is offline
Stage III
Default Flickering red tail lights
Does anyone know if it is legal to have the red LED tail light modual that flickers the stoplight 3 times before going solid in California?
Old 12-01-2009, 09:51 AM
SlowRain's Avatar
SlowRain
SlowRain is offline
Don't know...I do know there are DOT standards around it. I solved the problem (I think) by putting a BAL tailight on and put it at the bright "strobe flash" setting along with putting the rear turn signal brake light kit from HD on...so I have constant brake lights (both the turn signals and the tour pack lights) as well as a flashing one.
Old 12-01-2009, 11:32 AM
BiggDogg's Avatar
BiggDogg
BiggDogg is offline
You can probably find the answer on google.
It's Illegal in NJ, unless your a cop
Old 12-01-2009, 11:37 AM
RKRick1's Avatar
RKRick1
RKRick1 is offline
Not sure about CA, but I was told by my dealer that it is illegal in PA.
Old 12-01-2009, 02:41 PM
DDeFendi's Avatar
DDeFendi
DDeFendi is offline
Default Legality of Brake Modulators/Flashers
If they were illegal, then, would you not be breaking the law if you tapped your brake three or more times quickly before applying it continuously ???
Old 12-01-2009, 02:43 PM
Vatorman's Avatar
Vatorman
Vatorman is offline
I'll take my chances with a ticket. I have my BAL set to flash three times and go solid for stops.
Old 12-01-2009, 03:00 PM
Boxer 6's Avatar
Boxer 6
Boxer 6 is offline
Are you sure? Ive got them on my Street Glide and my wife has the module on her Fatboy.
Old 12-01-2009, 03:23 PM
mcrider1's Avatar
mcrider1
mcrider1 is offline
These folks make one that is California legal or so it says on their website.
http://www.hyperlites.com/calidf.html
Old 12-01-2009, 04:05 PM
2003Springer's Avatar
2003Springer
2003Springer is offline
Don't think you will be bothered! If they stop you for that They were going to stop you anyway.
Old 12-02-2009, 12:07 PM
FLAGS's Avatar
FLAGS
FLAGS is offline
Stage III
Default Thanks
Thanks for all your insites. I just took possession of a 2010 Road King Standard and want to be safe. The flashing tail lights seem like a good idea if it could only apply to Motorcycles only.
Again, Thanks!
Quick Reply: Flickering red tail lights
