Notices
Relocated the coil on my Ultra Classic
Old 11-30-2009, 09:08 PM
HDV2win's Avatar
HDV2win
HDV2win is offline
5th Gear
Default Relocated the coil on my Ultra Classic
I got bored with the left side of my 2005 Ultra Classic so I moved my coil to where the horn was.
Attached Thumbnails Relocated the coil on my Ultra Classic-img_0527a.jpg   Relocated the coil on my Ultra Classic-img_0528a.jpg
Old 11-30-2009, 09:15 PM
maineultraclassic's Avatar
maineultraclassic
maineultraclassic is offline
So where did the horn go?
Steve
Old 11-30-2009, 09:17 PM
96ApeKing's Avatar
96ApeKing
96ApeKing is offline
There is something said about the different lengths of the spark plug cables playing a part with firing or something. Can't really remember what it was since I didn't think I would have done what you did but does it run any different?
So, where is your horn now? I've seen some with it in between the downtubes.
Old 11-30-2009, 10:05 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
I like it. Looks Sharp!
Old 12-01-2009, 03:21 PM
fireaxxe's Avatar
fireaxxe
fireaxxe is offline
That coil is gonna get a tad bit hotter in that location. Also like was said earlier the shorter wires will advance you timing so you should retard it a little or it may fire too early causing damage especially when its hot
Old 12-01-2009, 04:24 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
as long as the resistance in ohms is between 5K and 11,666 there should not be a problem. I also doubt there will be much heat difference between that and stock location as it is in the air flow.
Old 12-01-2009, 04:26 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,949 Likes on 1,933 Posts
Nice. I would have put the coil upside down from how it is, but it looks good nonetheless.
__________________
Old 12-01-2009, 04:35 PM
mtclassic's Avatar
mtclassic
if it was upside down wouldn't all the juice fall out? LOL. It might look a little less cluttered that way.
Old 12-01-2009, 05:52 PM
HDV2win's Avatar
HDV2win
HDV2win is offline
5th Gear
I moved the horn to where the coil was,best part is I didnt have to change any wiring except for the spark plug wires. I havent noticed any difference in how it runs. The thing that cost the most was the chrome coil cover,its not after market it is oem for Dyna models so it was $75 ,spark plug wires were $36 and the bracket I made myself.
Old 12-01-2009, 07:10 PM
'05Train's Avatar
'05Train
'05Train is offline
Had the coil there on the 'Train for 5,000 miles give or take. No issues at all. Nice job, I think it looks much better than the cowbell.
Quick Reply: Relocated the coil on my Ultra Classic
