Radio and Speaker Installtion
Hello All,
I've just purchased a 2006 Electra Glide Standard. Got a great deal on it but it is the absolute bare bones model. Picked up the Harmon Kardon radio and some Hog Tunes speakers to install.
My question is once i remove the fairing and attempt the install do i need any additional hardware (screws or brackets for the speakers? wiring harness?) or should everything be all set back there.
Sorry if these questions seem terribly basic. Brand new to this and just looking for some advice.
Thanks in advance,
Bob
Thanks in advance,
Bob
That depends on what came with the Harmon Kardon radio when you purchased it. I installed a Sony Xplod and needed to purchase an install kit (Hawg Wired) that included a bezel, bracket and wiring harness. I also needed an adaptor in order to use my handlebar controls. Most 5.25" speakers will fit with no problems.
You shouldn't need anything for the HK installation. The plastic tray that's in the opening is held in place with four screws. Remove the tray and install the HK using the four screws to secure it to the fairing brackets.
The bike has the wiring in place. There's a large 23-wire connector that plugs into the back of the HK and it will only go in one way.
Not sure about the speaker installation. There will be speaker adapter rings that the speakers attach to and are secured with three screws (two long, 1 short) even though the speaker will have holes for four screws. You probably re-use the screws that are already there. Mount the speakers so that the spade terminals (male) are on top. The bike's wiring harness has the speaker connector terminals and they too will only install one way.
Don't know if the Standard comes with an antenna cable or not. Many prefer in-fairing antennas--TuneTrapper, Dakota Digital, J&M, etc.
Suggestion: Buy the HD service manual for your bike. It has all the information you need for this and other projects you will likely undertake, as well as wiring diagrams. Buying a used bike, you can never be sure that something wasn't altered by a previous owner.
