Fairing Radio Question
Amp.......
i have been looking through the forum for a new fairing and radio set up....fairing I am either going with the Woody or the Hong Kong on EBay....AMP will most likely be an ARC...link below
http://www.arcaudio.com/Motorcycle.asp
Currently I'm running with a Panasonic headunit, the Biketronics retrofit adapter, Biketronics 5.25" speakers and the Hogtunes tweeter pod. I'm satisifed with the tunes even at highway speed.
On road trips I use the IMC bluetooth headset and have it paired to my iPhone. I use the iPhone obviously for incoming calls but also for tunes and navigation. Listen to stereo music and if a call comes in music stops and automatically picks up the call. If a turn is coming up navigation directions will cut in and tell me which way to go. Love the setup.
As far as an amp. Sure, would like to get one just to get more power but don't really need it plus don't have the $$$ right now. When/if I go with an amp I would either go with the Biketronics or the J&M amp that they are working on.
Hope this helps.
Hope this helps.
I just got the Woody's fairing. It has 4 5" speakers and it's plenty loud with my sony head unit, no amp. my wife on her bike behind me to "turn that **** down or get louder pipes".
You can't go wrong with the Woody's fairing and the sony head unit is like $119. fairing comes with the speakers!
I am dumb when it comes to this. What am I looking for when I look at the RMS? Here are the specs on the speakers I want:
3-way 6"x9" speakers (pair)
injection-molded mica-filled polypropylene woofer with polyether foam surround
2" Mylar cone midrange driver, 3/4" silk dome tweeter
4-ohm impedance
2-70 watts RMS power range
frequency response: 53-22,000 Hz
sensitivity: 93.0 dB
depth: 3-1/4"
warranty: 1 year
4-ohm impedance
depth: 3-1/4"
warranty: 1 year
