woods tw-6 or andrews cams
Old 11-29-2009, 06:54 PM
palatium's Avatar
palatium
palatium is offline
Default woods tw-6 or andrews cams
which is better ? was thinkin of doing the whole stage 2 kit and due to lack of cash im going to get the cams ( where can I purchase for a good price ? )and pcIII from fuel moto.
Im hearing good things about both companies on the cams.
Old 11-29-2009, 07:04 PM
harley-jones's Avatar
harley-jones
harley-jones is offline
Don't take this the wrong way, but for your question the Search function would be your best bet. There are pages of post on cams. Check it out and you should find what your looking for.
Old 11-29-2009, 07:11 PM
timberland's Avatar
timberland
timberland is offline
Location: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Woods cams are ground by Andrews per his specs. As well as T-Mans. There still are differences as each "builder" has what works best for them. Asking what are better on this forum is like asking what oil is better or color of bike is faster.
I like Woods cams, also Mobile 1 oil and black harley's are faster.
Old 11-29-2009, 07:14 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
well known fact,red bikes are faster
kirby
Old 11-29-2009, 07:34 PM
maineultraclassic's Avatar
maineultraclassic
maineultraclassic is offline
Mine is red and black............so I must be super fast!!
Steve
Old 11-29-2009, 08:17 PM
Steelknee57's Avatar
Steelknee57
Steelknee57 is offline
You can call FuelMoto. He has a thread going on his install of the Woods 6 cam and PC tuner. I'm pretty sure he is selling a package for what you are talking about.
Old 11-29-2009, 08:28 PM
palatium's Avatar
palatium
palatium is offline
Default you guys crack me up !!!
steve that was funny, thanks steel , Ill check with jamie tomorrow
Old 11-29-2009, 08:30 PM
stro1965's Avatar
stro1965
stro1965 is offline
I went back and forth for a while between the Woods 6-6 and a couple of the Andrews cams. Bottom line was that the Andrews cams were about half the price and that won out for me.
Old 11-29-2009, 08:40 PM
fripple's Avatar
fripple
fripple is offline
Can't go wrong with either. Woods are proven time and time again to make the big time TQ.
Old 11-29-2009, 09:18 PM
PhilM's Avatar
PhilM
PhilM is offline
The most important thing to consider is that ANY (every) cam has an optimal set of conditions, under which is performs best. Things like displacement, compression ratio, bike model, gearing, head setup, intake / exhaust (to name a few) all play into the equation. Furthermore, riding style, where ya live, fuel quality are also factors.
For example, a Wood 6 likes 10+: compression, and when properly setup will make good power and ride well. However, if you throw them into a stock motor they may not respond as well as something like an Andrews 26. But if you change things up later on, the 26 will not be happy with much more than 9.5:1 static compression.
The "right" answer (if there is such a thing) is a little more complicated than just "Which one is best?".... Despite what some may lead you to believe.
Quick Reply: woods tw-6 or andrews cams
