starting problems for 2007 ultra
seems to be worst on cold nights ,push starter switch and no sound, i can tap on the starter with my knife and it will finally engage the starter. sometimes i just tap a few times ,other times it takes a lot. The starter connections are tight, and all bolts are tight. any help will be appreciated .
rwhite15
rwhite15
Click HERE to download what might be your problem. I had the same exact problem on my 08. It ended up not being that though, it ended up being the ignition switch. I was always tapping my starter, but then I figured out if I wiggled the ignition switch it would fire right up so the switch was replaced. However, check both the ignition and the bulletin. Mine also had no sound whatsoever.
my brother has a 07 ultra and has the same problem. It onkly happens once in a while
but he hits the starter button and nothing. sometimes it would take about ten menutes
before it would finely start. He put a starter button from j&p cycle that mounts on the
solenoid. it is about 50 smacks but works every time. The starter switch on the
handle bars is not affected
