Battery Tender question
Old 11-27-2009, 08:27 AM
dooz28's Avatar
dooz28
dooz28 is offline
Default Battery Tender question
Can a Battery Tender simply be plugged into a touring bike's cigarette lighter (on a 2009 FLHT in this case) using the appropriate adapter, or is it necessary to run a pigtail directly from the battery? Your patience with my limited electrical knowledge is appreciated.
Old 11-27-2009, 08:33 AM
Stretglyd08's Avatar
Stretglyd08
Stretglyd08 is offline
I've been running a battery tender on my bike for years through the pgtails off the battery. I didn't get an adapter to go to the lighter. I don't know if I'd run a charging unit through an auxillary input.
Old 11-27-2009, 08:34 AM
wolfman 66's Avatar
wolfman 66
wolfman 66 is offline
When the ignition is off there is no connection to the battery from the lighter so this will not work. Only takes a few minutes to hook it to the battery.
Old 11-27-2009, 09:50 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
You DO need a pigtail direct off the battery! I have fitted an accessory socket into the side-panel near my battery to take my tender. Looks similar to a lighter socket, but smaller, with a hinged cover. BMW bikes come with one standard and I got mine from an independent BMW parts shop.
Old 11-27-2009, 10:01 AM
frenchbiker's Avatar
frenchbiker
frenchbiker is offline
No cause there's no power to the lighter when the ignition is off. Your battery tender should have come with a pigtail connected to the battery via 2 rings. You leave it on the bike and connect the battery tender whenever you need.
Old 11-27-2009, 10:12 AM
gregbenner's Avatar
gregbenner
gregbenner is offline
BMWs do come with one. Only problem is their elctrical system is so complicated it requires a $200 (yes two hundred) special BMW charger to work
I wired mine direct to the battery as well.
Old 11-27-2009, 10:16 AM
brockstwrt's Avatar
brockstwrt
brockstwrt is offline
Are you sure the pigtail isn't on there already? My 07 vrod came with it on and my 10 road king has it on already too. Check under the seat on the front side of the battery it might already be there. I think harley does this so you'll buy their tender.
Old 11-27-2009, 10:19 AM
IzzoQuazzo's Avatar
IzzoQuazzo
IzzoQuazzo is offline
Retired Admin
Received 9,041 Likes on 3,711 Posts
Harley does not include the pigtail. Some dealers install them theirselves. Mine does this, but then charges for the Battery Tender seperately. I bought mine at Walmart.
Old 11-27-2009, 10:47 AM
88racing's Avatar
88racing
88racing is offline
Its best to put the pigtail on the battery.
The cigarette lighter is off when the ignition is off.
Old 11-27-2009, 11:08 AM
tibadoe's Avatar
tibadoe
tibadoe is offline
Hook a pigtail up to the battery and you are good to go.
Quick Reply: Battery Tender question
