Which PC-V map is best.
My question is I got 2 maps from Jamie at FuelMoto and just wondering if someone can tell me if they are using the same maps and how their bike is running. Just wondering if there is a better map to use. The 2 maps I have are M15-818-Trudualslipons and M15-818-Trudualmpg. The setup I have is 08 StreetGlide with V&H Dresser Duals, V&H MonsterOvals and Stage 1 AC. I also have a map switch so I can switch between the 2 map. If anyone is using this setup, what map are you using and how does your bike run. My mpg is about 35 mpg is this about what I should be getting. The mpg doesn't seem to change regardless which map I run.
