Windshield Screw Insert Question
I was getting ready to head over to the parents house for Thanksgiving dinner when I noticed the left side of the windshield was loose.
Upon further investigation I noticed that the brass well nut had completely separated from the inner faring. I tried to push the well nut back in but once I tighten the screw it just pop's right back out again.
I've searched and read the posts about the new replacement inserts P/N 16585-96 but was wondering if this will fix the problem since it appearers that the current insert has nothing to hold on to, to keep it in place.
Thanks in advance and I hope everyone had an enjoyable Thanksgiving.
The insert's will fix Your problem. I had the same problem on My 08UC. A buddy of mine recommended using a little (very little) silicone on the bolt threads. I did so and torqued the bolts to 22 in lbs. That was over 1-1/2 years ago and never had a problem with the bolts coming loose again.
I had mine done at the dealer not once but twice they put them in backwards the first time. the kit comes with three brass ferrule the slots go in first not out towards the windshield and there is a install tool to put them in. some guys on the forum have used the wind shield screw to install also. the slot cuts the threads in the plastic be carefull if you try yourself, make you start them in straight.
