Windshield Screw Insert Question
Old 11-27-2009 | 08:18 AM
dirtdobber's Avatar
dirtdobber
The slots are not designed for a screw driver.
I thread the inner fairing then use a bolt. Takes only a few min. and they do not come back out.
dd
Old 11-27-2009 | 08:40 AM
santajim's Avatar
santajim
Mine pulled and like already said I used a little JB weld on the sides of the insert and it is stronger than original.
Old 11-27-2009 | 10:22 AM
SciFiGuy's Avatar
SciFiGuy
Thanks everyone for the responses.
I'm here at the dealer now having it taken care of since they will do it under warranty. Waiting to see if they just replace the one or all three. If they only replace the one then I'll pick up a few extras and keep them in the tool bag of the bike just in case I need them latter.
Once again this is the best place to come to if you have a question about your bike.
Thanks again.
Old 11-27-2009 | 10:39 AM
BAGGERNATE's Avatar
BAGGERNATE
I had 2 of the 3 well nuts on my 01 EGC come loose. I used a 2 part epoxy to reset them 3 yrs ago. Still holding. I'm a little more careful when tightening them now. I suppose epoxy is similuar to the JB weld idea, just a little easier to come by when out and about or late at night.
Nate
Old 11-27-2009 | 11:57 AM
twistedcherokee's Avatar
twistedcherokee
I put on a shorter windshield & haven't had any more problems. I just pushed them back in.
Toby
Old 11-27-2009 | 12:39 PM
SciFiGuy's Avatar
SciFiGuy
Just got back from the dealer. As I figured they only replaced the one that came out. Went ahead and picked up some just in case any of the others should do the same thing.
Problem now is that when I was on the way home I noticed that the ABS light stayed on. Can't figure how they could have messed that up by just taking the outer fairing off. Turned around and told the service writer about it but they are unable to get to it today so I'll be spending most of tomorrow back at the dealer while they look into it.
Old 11-27-2009 | 01:44 PM
SciFiGuy's Avatar
SciFiGuy
Update on the ABS light.
Damn I love this site.
After doing a search here and checking the service manual (if you've not gotten yours yet I highly recommend getting one) it turns out the tech forgot to re-hooked the wire on the left side of the steering head that goes to the ABS when he put the outer fairing back on. I figured it had to be something simple but didn't think it would be that simple.
Plugged it back in and now every things the way it supposed to be.
Another BIG THUMBS UP TO HDFORUMS!!
Old 11-27-2009 | 04:52 PM
Sancho's Avatar
Sancho
Thanks again.
Come on SciFiGuy. The dealer is the best place to go if you want something screwed up, (as you just experienced). They ain't touchin mine unless it's a warranty item. Even then it would probably be a hassle.
leftyjm
2014-2023 Touring Models
08-31-2016 08:48 PM
the4thgearkid
08-17-2013 04:16 PM
the4thgearkid
06-01-2013 03:34 PM
Garemlin
07-10-2008 12:54 PM
twistedcherokee
08-12-2007 07:48 PM
Quick Reply: Windshield Screw Insert Question
