98" Pistons?
Old 01-12-2010, 10:53 AM
Dalton's Avatar
Dalton
Dalton is offline
You are just as bad as I am, can't leave well enough alone ! LMAO
Headquarters does sell CP Pistons - 3.938 bore with a 7cc dome for $391.40.
With HQ heads this is a 10.5:1 static compression, would be marginally different depending if your heads have been milled, chamber volume, etc.
Old 01-12-2010, 04:27 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
Originally Posted by maineultraclassic
Who is the recommended brand for 98" pistons?
I'm thinking about having my stock cylinders bored out to 98" and putting in a good pair of pistons.......is Wiseco the preferred brand?
I have 30000 on my 95" pistons, I'm going to do a CCP test on it over the winter and if it's down or leaking..............then 98" it is.
Steve
I got my 98" CP's from Randy (KOC) http://www.kingofcubes.com/ He cut 10cc domes down to 6cc and bored the cylinders to match. I couldn't be happier.
Rick
Old 01-13-2010, 06:35 PM
DOUBLE-D-LOWRIDER's Avatar
DOUBLE-D-LOWRIDER
DOUBLE-D-LOWRIDER is offline
Help.............going f~!@#$king nuts....gonna do the 95" kit....now what compression...wanna do bolt in cam later.............what cam ????????
Maybe can do 95" and cam....at same time.............this has got to be simpler than this....how ya ride...what ya want...how much $$$$...if $$$ wasnt a problem..i might ride someting that no one could touch....not like my 03 fxdl.....goingin for therapy if i dont get some answers..................nuts in wisconsin...(long winter) lol
Old 01-13-2010, 07:50 PM
timberland's Avatar
timberland
timberland is offline
Location: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
one name in pistons "Wiseco"...http://www.wiseco.com/Catalogs/VTwin/TwinCam8896.pdf
take the CC's listed and divide by 16.3870641 to obtain C.I.
Or , take C.I. and multiply by 16.3870641 to obtain CC's.
Old 08-07-2010, 07:55 AM
maineultraclassic's Avatar
maineultraclassic
maineultraclassic is offline
Originally Posted by WVULTRA
Steve:
Axtell's new "drop on" kits look promising:
http://www.axtellsales.com/
And Herko's an Axtell Dealer!
I was just playing with the calculators again, and these 97" kits look like they will fit my needs better then the 98" kits will. I'm looking to raise my compression just a bit to better fit my cams needs, I'm set on paper at 10-1......but when I enlarged the relief pockets in the pistons I'm sure that dropped it down a bit. So by going to 97" with pistons that I won't have to work on, that should put the compression around 10.25-1 that the Woods cams want.
S&S has a 97" drop on kit with new cylinders for $725, and Axtell has a 97" drop on kit with boring for $460. I'll be doing this over the winter, so downtime is not a big deal to me as I'll have 4+ months to work with.
Steve
Hillsidecycle.com
Engine Mechanical Topics
11
12-15-2016 09:52 AM
GibsonSG
19
02-27-2016 10:00 AM
FL-kruzen
10-19-2012 01:48 PM
fryeca
Exhaust System Topics
19
03-02-2008 10:01 AM
hdpearson13
09-06-2007 06:57 AM
Quick Reply: 98" Pistons?
