Can you patch and/or plug a tire?
I carry a Stop & Go tire plug kit with all the time for emergency...but if I were to be home and have a small nail or similar object in a tire, I may be tempted to hot patch it from the inside....
It can be done, know some that have gotten good mileage from a patched tire...but I'm not recommending this practice...at you own risk....
Pull the nail and put in a tube. Then replace when its worn out.
I have successfully plugged my rear tire and still used up the remaining tire life. Since then, I found a product called "Ride-On". You put it in your good tires and if you find a nail, you pull the nail then ride. The hole is sealed by the product. Another beneficial side-effect is that the product balances your tires. If you do a search, you will find that a lot of people here would recommend Ride-On.
http://www.ride-on.com/prod_mot.asp
