Can you patch and/or plug a tire?
Old 11-24-2009 | 05:48 PM
gmc's Avatar
gmc
Originally Posted by Uncle Scrooge
What you need is called a plug-patch. It looks like a big roofing nail, and requires dismounting the tire to install from the inside. Dunlop refers to it as one of two approved ways to repair a flat. I recommend you look at the Dunlop website for info on flat repair.
I've ridden on two tires with this type plug, only safe way since they won't blow out. If you use a tube you risk the it getting pinched if the tire linning has a hole in it, ask me how I know. Everytime the tire rotates it flexes the hole and eventually can pinch the tube.
Old 11-24-2009 | 05:55 PM
2003Springer's Avatar
2003Springer
+2 on the tube
Originally Posted by dawg
+1 put in a tube.
Old 11-24-2009 | 06:13 PM
robbie52's Avatar
robbie52
If you have to pay someone else to remove, repair, and remount tire I would install a new tire unless there was a lot of tread left.
Old 11-24-2009 | 06:18 PM
Uncle Scrooge's Avatar
Uncle Scrooge
So would I. But that's another advantage of DIY tire mounting--you don't end up throwing away half worn out tires.
Old 11-24-2009 | 06:21 PM
OnTheFence's Avatar
OnTheFence
I plugged my front tire 20k miles ago. Works great. Just used cheapo tire plug kit from Autozone.
Old 11-24-2009 | 06:22 PM
09flhtc's Avatar
09flhtc
can you yes should you no
Old 11-24-2009 | 06:45 PM
richro123's Avatar
richro123
Plugged my front tire still holding fine went to Key West and back no issues.
Old 11-24-2009 | 07:07 PM
FLoTR's Avatar
FLoTR
Originally Posted by Sheep
Pull the nail and put in a tube. Then replace when its worn out.
"wurd"
Old 11-24-2009 | 08:22 PM
TMair's Avatar
TMair
I think the first thing I would do is pull the nail and see if the tire looses air, if it does I would plug it and ride on, lets just say that the plug begins to leak at some future point, the tire is not going to disintigrate, it will get low, you do check your tire pressure from time to time right!
Terry
craigcrewcheif
05-15-2014 02:08 PM
Roses
10-16-2013 10:48 AM
Motorbones
03-24-2011 08:48 AM
Getyurmotorunnin
10-16-2010 09:31 PM
fastbydrmike
04-19-2007 07:57 PM
Quick Reply: Can you patch and/or plug a tire?
