New Style Bags and Intoducing the New Top Shop Tri-Light Fender Cover
Hello Everyone!
Some of you may have heard of us before and some of you have boughted bags from us but for those of you who haven't here is what we have to offer!
The New Style Extended Bags(4 1/8 stretch) that Top Shop makes here are all vacuum injected. This is where the resin is forced into to the mold instead of using more conventional methods such as a chopper gun or traditional handlay. This helps us provide the customer with a part that has less resin(which creates shrinkage) more strength(5 times the compeditors) and reduces the all around weight (4-6 lbs each) of the bags. The process also allows us to speed up production times and save on waste that accumulates. Which lets Top Shop save in cost and the environment at the same time.
The option of having the bags carpeted also have it's benifits. Not only does it look stupendous but we also insert a carpeted divider. This give the customer the option to keep tools, oily rags or what have you in the bottom of the bags extention(a quart of oil fits perfect) and their valuables/clothing seperate above.
Top Shop Custom Bags also offer the customer to have a wide range of exhaust cut outs. They can either choose from a single cut out, a dual cut out or flat backs. Top Shop Bags can also be cut to fit larger or oddly shapped exhausts, such as ovals or over sized pipes.
Top Shop Custom Bags can also be cut down offering the customer the option of having 2", 2.5" , 3", 3.5" or a 4 1/8" bag stretch. Instead of just being given one size you get 5 and to top it off you can also have a sloped stretch. This means that you can go from a 1" stretch in the front of the bag, down to a 3", 3.5" or 4 1/8" in the rear!
Now for the Top Shop Tri-Light Fender Cover!!
This fender was created basically for the customer to keep their tri-light and still be able to get a stretched fender to match with the bag stretch of thier choosing. Designed to slide under the rear bar and attatch at all OEM points with very minor fabrication involved. Customer will be able to use OEM taillights or their choice of lighting for the Top Shop Tri-Light Fender Cover!
The covers are made of the same materials as the Top Shop New Style Bags but only these are hand layed instead of being vacuum injected. Still a very solid,durable part all around with straight lines and a unique look!
To install the Top Shop Tri-Light Fender Cover all that is needed is to drill out 2 hole a 1/16 bigger to accomidate the larger bolts that are need to compensate for the added thickness of the fender cover. That's It! The Top Shop Tri-Light Fender Covers also come with a foam backing on them. So on the install the customer isn't scratching their OEM fender if they would like to swith back. The tri-light is secured by a lower bracket and then 2 bolts that will be attatched to the fender upon shipping. Directions for easiest install and trouble shoot will be included in the order as well if there are any unforseen problems that arrise.
Pricing-
Effective immediatly on the 4th of January this new year the prices of bags will be as follows:
New Style 4 1/8"(full stretch) - 3" $799.00 Carpeted/Shipped Anywhere in the Lower 48 States.
Painted Vivid Black- $1,050.00 Carpeted & Shipped
Painted Red Hot Sunglow-$1,350.00 Carpeted & Shipped
Black Pearl- $1,100.00 Carpeted & Shipped
Top Shop Tri-Light Fender- $399.00 Shipped/ This includes bolts, install/troubleshoot guide and foam backing.
Thank You,
Justin B
Pricing-
Thank You,
Justin B
