? on the fog lights/driving lights
i also notice tonight that my headlight glass seems to be like foggy or dirty is there a way to clean it and what would u guys put in as a brighter headlight.also the passing lamps are they bulbs or is it a whole lamp to change them into yellow passing light.if you have any pics it would be great
Wiring Question
Hello Mick,
This is an old thread and I thought I would try anyway. I just bought these sealed beam lens/lights and at present, I have halogen bulbs. As it applies to wiring, do I just cut the existing wires to the halogen bulbs and twist and attach to the terminals on the Wagners?
Regards,
Tim
QUOTE=Mick;5871848]I have yellow (amber) lights on mine.
I switched them to Wagner 4415A sealed beams last year.
The Wagner beams are a screw terminal as opposed to the plug in style , but it's pretty easy to change.
They're available at most better auto parts stores and are for trucks as a fog beam.
The 4415 and A series have about a 40 degree beam spread as opposed to the stock 8 degree spread.
They are 35 watt , unlike the stock 27 watt bulbs , so the wiring is OK afterwards.
Maybe it's me , but "less" people seem to cross in front of me since the change to amber.
Take care to aim them carefully if you install as the beam changes position significantly when chaging from spot to flood style lights.
And yes , they are really a pain to aim properly.
I feel like this mod was a good value , and I feel safer with them , than the stock bulbs.
Mick[/QUOTE]
Regards,
Tim
Mick[/QUOTE]
