Just a heads up on HD oil cooler
I just wanted to let folks know than on 09 and maybe 10's you cant run an HD oil cooler if you are running a thunderheader. At least thats the case on the touring models. The reason is that the O2 sensor is right in the way of where the cooler needs to mount. I found this out the hard way. Anyone else have this problem and figure out how to run the cooler or perhaps another brand of cooler?
what about jagg oil coolers? they mount differently, ya can always try calling em to make sure.
http://www.jagg.com/jagg%20files/jag...ges/cooler.htm
Depending on how much clearance is needed, you can get a dummy o2 sensor or bolt that will fitin the sensor opening and heat it up with a torch, then bend it where you need it. I did it to mine, but i'm running rinehart td. I just bent it up a little so the o2 sensor wire's weren't so close to the oil cooler housing.
