Dyno numbers SE-255 Cam Change
Old 11-19-2009 | 11:04 PM
harley-jones's Avatar
harley-jones
Default Dyno numbers SE-255 Cam Change
08 SG, 96 in., Reinhart TD, SERT, SE air cleaner, SE-255 cams
It came off the dyno today. Here are my numbers.
Max power= 81.89 @ 5200rpm's
Max torque=91.94 @ 4000rpm's
I picked up 11 horse power and 12 ft/lbs of torque over the stock cams.
Torque starts dropping off at 4500rpm's and by 5000rpm's it drops to 82 ft/lbs. That is still 10 ft/lbs more than I had with the stock cams at 5000rpm's.
I am pleased with these numbers and does it ever sound good. A little louder out the exhaust and a little more chop to the idle.
Valve train is as quite as stock.
Now it's time to rock and roll and rack up some miles.
Old 11-19-2009 | 11:10 PM
CigarCritic's Avatar
CigarCritic
You should be, those numbers should give you a good roll on in 6th gear. Congrats.
Old 11-19-2009 | 11:19 PM
davewear's Avatar
davewear
I'd like to see the chart for that, maybe your getting big torque early on? 80ish hp and 90ish ft/lbs is what one should hope to see with a stage 1, good tune without cams....
Old 11-20-2009 | 01:19 AM
harley-jones
It is 85ft/lbs at 2800rpm's...
90ft/lbs at 3200rpm's
Then it tops out at 91.94ft/lbs at 4000rpm's
then stays in the 90ft/lbs till 4700rpm's
Old 11-20-2009 | 02:10 AM
joker1450's Avatar
joker1450
What about the tuning? What map did you use?
Old 11-20-2009 | 02:32 AM
leohd's Avatar
leohd
congrats enjoy
Old 11-20-2009 | 07:52 AM
harley-jones
Screaming Eagle Race Tuner...SERT
Old 11-20-2009 | 08:33 AM
joker1450's Avatar
joker1450
Dyno-tuning or by yourself?
Old 11-20-2009 | 08:35 AM
scooby doo's Avatar
scooby doo
Not to downplay it or make it seem like nothing was done, but I'm getting slightly better with the same setup without a cam change, just a tune. (same bike setup, same year).
Just saying only because I was thinking of doing a cam or contemplating a 103/107.
Old 11-20-2009 | 08:41 AM
harley-jones
Dyno tuning
Quick Reply: Dyno numbers SE-255 Cam Change
