Dyno numbers SE-255 Cam Change
What are your numbers? It sounds like you are making some great numbers. Be happy my friend and saved your $$$$.
My Stage one numbers before the cam change were a little anemic :
Max power=70.98
Max torque=80.54
With Cam Change:
Max power=81.89
Max torque=91.94
Thanks for knowing I wasn't intending to downplay the cam.
I'm at 79 hp 92 tq. Same year and set up but I wasn't sure which ac you're running. I've got the SE HD AC. Not that it means much because I think any stage 1 ac will bring in more air then the bike needs.
I just had the 3 hours dyno at the shop. Bike pulls pretty good low but I want more hence the possible cam change or bump to 103/107.
