Fuel Moto Cam Testing results Video Dyno Charts
#51
Platinum Sponsor
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#52
Jamie, Everything else being equal, can you compare the torque curve from 1800rpm to 4500 rpm of these woods cams to the Se255 cams
#53
Platinum Sponsor
Because I have not tested cams on the same day, on the same bike, with the same exhaust combination, etc.. all things are not equal for comparison. However, from the bikes we have tested with SE 255 cams they make similar power to the Woods TW6-6 from 2000-2500 RPM's but from 2500 on upward the TW6-6 makes signifigantly more power than the 255's.
#54
Platinum Sponsor
Althought the TW5-6 has 3 degrees earlier intake open/closing which will move the torque peak slighly lower than the TW6-6, it has more lift and less duration than what we were looking for in a "do everything" cam. With the TW5's .575 lift I recommend changing valve springs as well.
#58
I plan on installing the 6-6 cams this winter with a 4deg gear. Since I have a PC V and auto tune with Powerduals, Montser ovals and a Heavy breather, how much benefit do you think having the heads ported and milled to flow better and bump the compression? Also do I need to have compression releases put in if I do not do any headwork or even if I do? The motor is stock for now.
Jamie did you use the 4 deg gear on your build and how well does it start?
#59
Platinum Sponsor
#60
I diddnt use the 4 degree advance gear on our testing. The specs of the cams were already what I wanted and the specific Hp/Tq numbers we projected were reflected in the final dyno #s. The advance gear adds cost and more importantly increases cylinder pressure, our bike starts like a stock bike. These motors will benefit from porting and if you are raising the compression I would recommend not running the advance gear.
Hows the snow up there? I will see you in a few months to tune some bikes for me.
I would try this cam set when you get a chance on a stock bike with your pipe combo. Your idle and start up will be fine with these. My 2 cents...
Twin Cam
TR-525C TMan cams
Open
Close
Lift
Duration
Centerline
TDC
LSA
Overlap
Intake
23
41
525
244
99
212
100.5
44
Exhaust
45
21
525
246
102
196
Close
Lift
Duration
Centerline
TDC
LSA
Overlap
Intake
23
41
525
244
99
212
100.5
44
Exhaust
45
21
525
246
102
196
Chain drive bolt-in Cam, no head work required. Works well at 9.1 to 10.1 compression. A very good combination with flat top pistons and stock heads. Horsepower and torque increase with smooth ride.
