RWD stretched tank
RWD stretched tank
Anybody running an RWD stretched tank. Thinking about going that route. Wondering about the gas in the upper curve, all 5.5 gals used or is there pockets that would hold gas. Front of the tank looks like it would hold. Anyway to calibrate the fuel gauge (mines actually accurate) Does the front sit any back then OEM. Any one have any pics.
I put one on my bike and am just getting it going. I am having some problems with the fuel gauge not working. When you installl the pump and all of the hardware from the stock tank you have to put a bend in the arm that holds the fuel pick-up. I might have it rubbing the outside edge (or center channel)of the tank. As far as being able to use all of the fuel, I think it will drain from side to side/front to back OK. I really like the looks, it made my bike build as much as any single thing I did.
