Just got my tour back
Old 11-28-2009, 08:55 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Originally Posted by boneziff
Here ya go Q hog here's what I did hope this helps. Iam very happy with it I just need to plug the ends of the tubes when I find the right plugs.
Very, very nice job and bike. Wish I'd have taken a welding class instead of that fourth year of French in high school back in the day; although, there were some cute girls in the French class and the teacher was smokin' hot.
  #72
Old 11-28-2009, 11:22 PM
gilbos440rt's Avatar
gilbos440rt
gilbos440rt is offline
LOL! Sounds like my Spanish class!
  #73
Old 11-28-2009, 11:50 PM
INZANE's Avatar
INZANE
INZANE is offline
looks sweet... thats a beautiful bike
  #74
Old 11-29-2009, 02:01 PM
ron bayless's Avatar
ron bayless
ron bayless is offline
Originally Posted by q hog
just got my tour pak (aftermarket) back from the paint shop. What you think? All i need now is to install the all the hardware. Nervous bout doing that!! Any advice prior to start drilling!!!!!!!!!
that is one fantastic looking bike
  #75
Old 11-29-2009, 02:30 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
I know I am late in posting this but make sure you put the lid gasket on before mounting the hinges and latches. I know it sounds stupid but I have seen people make this mistake.
  #76
Old 11-29-2009, 04:30 PM
katobird's Avatar
katobird
katobird is offline
Totally agree...layout where the holes go, but put some kind of tape over the area BEFORE YOU DRILL.
remember a standard drill bit will "bite" hard and go thru quick.
start with a small bit 1/8" first then step it up to boly diameter final size.
  #77
Old 11-30-2009, 09:08 PM
Q Hog's Avatar
Q Hog
Q Hog is offline
Boeziff, that set up is great. You need to make me one of those brackets.. It looks great. I have to raise my T/P in the front and back atleast 1 3/4" to allow the the bags to open up.
  #78
Old 11-30-2009, 09:21 PM
FunkyNova66's Avatar
FunkyNova66
FunkyNova66 is offline
Hey Q-Hog, did you ever get it mounted? Your killing us with the suspense! LOL
  #79
Old 11-30-2009, 10:38 PM
Harleypingman
[quote=Q Hog;5910801]Boeziff, that set up is great. You need to make me one of those brackets.. It looks great. I have to raise my T/P in the front and back atleast 1 3/4" to allow the the bags to open up.
Q, what rack are you using to mount the tour pak? I ask because that 1 3/4" dimension is way different from my experience mounting a King tour pak on an HD two-up detachable tour pak rack. The HD tour pak rack uses a chrome u-tube (included with the kit) between the tour pack and rack. I used automotive suspension rubber bushings between the U-tube (that was at the bottom of the tour pak) and the rack's top surface. I had several of the automotive bushings left over and measured one: it's about 5/8" thick. Even with thin stainless steel washers sandwiching the bushing, that's nowhere close to 1 3/4".
Good luck with your installation.
  #80
Old 11-30-2009, 10:58 PM
Q Hog's Avatar
Q Hog
Q Hog is offline
Pingman, I could be wrong on the exact measurements. I have the detachable T/P rack with the U tube.
Nova66, Its not mounted yet. I just have the holes drilled for the detachable rack, inserted the rubber molding and brought and drilled an aluminum base plate to support the T/P floor. Been kind of busy..
Quick Reply: Just got my tour back
