will streetglide turn signals fit with lower fairing covers
i have an 03 flh standard that i put lowers on and i was wanting to change my old style passing lamp turn signals to the small street glide turn signal assembly but was not sure it worked with lower leg covers. anyone have a street glide with lowers on them or know if they work
I have the SG turn signal brackets and signals with VENTED fairing lowers on my '04 EG.
EDIT: Apparently, non-vented lowers don't work with the SG turn signals/brackets, so I edited my reply to confirm that I have vented lowers on my bike.
with the older style lowers (non-vented) which I happen to have. I read on their website that the bullet lights will not work with the older style non vented lower fairing. sucks.
i was wanting to clean the front end up and just have bullet turn signals but if i have to i can keep the running lights and get the that part to clean it up a bit.
Yep I wasn't sure if you wanted to get rid of passing lamps. I kinda like the passing lamps for the visibility. I had this bullet kit leftover from a Fatboy I use to have and even though part number says for softails the kit has everything(minus light bulbs & lenses) you need to replace the pancake signals on Electra Glide. It's relatively cheap ~$60 too.
since the bracket that harley sells doesn't work with unvented lower farings I ended up making my own bracket and buying some bullet turn signals. i think it came out pretty nice.
Reason: lost pics
