MPG: What do you get?
#41
2008 EG Standard, all stock w SE slip ons and Nightrider IED.
Did 48 mpg twice, Once with a strong tail wind and once putting around at 45 - 50 mph.
Did 24 mpg once holding the throttle open as much as I could.
WOT is kinda like a 100 mph cruise control.
But mostly 35 - 38 mpg w very little in town riding.
#45
I averaged 42.8 mpg on a cross country trip in early September. This was with two up and loaded. It would have been been better but I was tweaking the auto tune as I went. MPG started out in the low 30's and improved to a high of 48 mpg. Running interstate at 75 was 40 mpg + - depending on wind and speed.
#46
#48
#49
2009 RK PC-V, S/E aircleaner, Rinehart Slipons 42-47
Same setup but wht stock pipes and stock map downloaded PC-V 39-41
You'll also get a little better with 45psi in rear 40psi in the front tires, also lighter weight oils in trans and primary maybe 1-2mpg more, but its hell on the clutch, and trans in hott weather tho.
