Front Brake squeeling
RE: Front Brake squeeling
Lyndall pads do work and work well or I believe they say they give your money back if they don't. Paul SR and Paul JR are great business people that intend to satisfy your needs. A few things that may help it to remove the pads, chamfer the edges, sand the flat surface prior to this by placing a sheet of 220 snadpaper on a flat surface and give it a few swipes. Also there are brake pad stick on liners available in parts stores if all else fails that may help when applied to a clean pad back. The squeal is a viabration that is usually caused by a slight misalignment. Make sure that the pins that the calipers ride on are lubricated with the proper Hi temp lubricant.
Are you using any type of wheel cleaner? I cleaned my wheels a couple of months ago with Simple Green. The front brakes started to squeal... loud! I used them lightly and didn't clean them with anything but the Mr. Clean car wash system and the squealing vanished in a couple of days.
