Tire Valve Replacement
Old 11-14-2009, 05:44 PM
drharley's Avatar
drharley
drharley is offline
Default Tire Valve Replacement
I have an '08 Street Glide with the stock cast wheels and the "dreaded" rubber valve. I want replace it with a steel valve and install the Tiregard tire pressure monitoring system (I was told that the manufacturer recommends steel/rigid valve stems).My question is has anyone used the TireGard system? And, has anyone replaced the rubber valve stem with a steel one without removing the tire from the bike and removing the tire? If you have, suggestions as to how you go about it?
Old 11-14-2009, 07:26 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
Don't know about the valves yet, but tell me more about Your experience with the tire pressure monitoring system. Have You used it in the past?
Old 11-14-2009, 07:52 PM
2003Springer's Avatar
2003Springer
2003Springer is offline
Keep it posted. Sounds interesting
Old 11-14-2009, 08:23 PM
CruzN's Avatar
CruzN
CruzN is offline
I have an 09 FLHT with stock rims. I have the hardest time putting air in the tires.
I bought a EZ-Tire gauge that allows you to connect it to the valve stem then use a standard air compress at a service station.
Old 11-14-2009, 09:01 PM
Uncle Scrooge's Avatar
Uncle Scrooge
Uncle Scrooge is offline
I don't see how anybody could change valves without dismounting the tire.
Old 11-14-2009, 10:06 PM
drharley's Avatar
drharley
drharley is offline
FYI-just looked at a utube of a tire valve replacement on a scooter using a C-clamp and a pair of vise grips. Nothing yet on a HD wheel and tire though. And, I have no experience with the TireGard that's why I put out the question.
Old 11-15-2009, 11:25 AM
dog155's Avatar
dog155
dog155 is offline
Cannot imagine how it could be done without breaking tire down.Never heard of it being done either.Good Luck
Old 11-15-2009, 01:38 PM
gunner11's Avatar
gunner11
gunner11 is offline
I don't see the problem, I've never had a problem putting air in my tires.
Old 11-15-2009, 02:38 PM
dklanecky's Avatar
dklanecky
dklanecky is offline
Here;s a solution for a solid mounted valve stem. Your gonna have to remove the tire to install it though.
Old 11-15-2009, 08:17 PM
drharley's Avatar
drharley
drharley is offline
I tried with the c clamp with no success. One side of the tire has to be moved off the rim to do the job right. Oh yeah, if you have trouble checking or airing up your tires, for $10 StopnGo.com has a nifty right angle extension air valve.
Quick Reply: Tire Valve Replacement
