Wheel fitment
Old 11-13-2009 | 06:17 PM
BuckeyeRider's Avatar
BuckeyeRider
Default Wheel fitment
Will a set of stock wheels from a 2009 road glide -ABS fit on a 2008 electraglide - ABS ??
The diameter is different but what about the hub/bearing set up?
Thanks
Old 11-14-2009 | 12:25 PM
FastHarley's Avatar
FastHarley
Former Sponsor
could you please make your self more clear? I will check back and answer your question once I know exactly what you mean.
Old 11-14-2009 | 12:32 PM
BuckeyeRider
Thanks FH,
I was checking to see if wheels from a 09 roadglide would fit on mt electraglide. The 09 roadglide has a 17" front but I don't know if its the same hub and bearing size.
I know the 09 electraglides will not fit the 08 but I don't know allot about the RG
Old 11-14-2009 | 02:49 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Could you explain why a 09 will not work on a 08? All front hubs all use a 52 mm bearing OD. The same sealed bearing 3/4", 1", and 25 mm axle are all 52 mm. I do not care if it is a Dyna, Sportster, or bagger. If it is a sealed bearing than it is 52 mm OD. 3/4" and 1" are ie: 52mm X 25 mm X 1" or 3/4". All bearings with a 25 mm axle are 52 mm X 20 mm X 25 mm. The bearing on the left hand side is a different part # for either the ABS and non ABS. The ABS has a indicator in the bearing that registers on the wired ABS senser. The non-ABS has a spacer where the sensor was on the ABS drawing and the non-ABS bearing does not have a indicator.
Old 11-14-2009 | 06:04 PM
BuckeyeRider
I wish I could explain why it won't fit. I've called 3 dealers and they all tell me the samething. They say the 09 will not fit the 08. I don't know the change point and they couldn't tell me allot either. They simply say that by part # their wheels state ##- 08 and a different part number for 09-10
A dealer down the road has a nice set for 2010 at a great price (18" set) and said they won't work on my 08.
Is this BS from Harley??? I don't know.. That's why I was asking on here.
From what you tell me tho is that they should.
Old 11-14-2009 | 06:26 PM
lp's Avatar
lp
An 09/10 front wheel will fit an 08. Axle, brakes, forks are identical.
There may be some differences in the ABS sensor bearing but I'm not sure.
If it is different...press out the 09 bearing and insert the 08 bearing.
An 09 Rear Wheel is not going to fit your 08. The Rim/Tire is too wide for your 08 fender.
lp
Old 11-14-2009 | 07:17 PM
BuckeyeRider
lp
Thanks LP
1Blackhatch
Wheels/Tires
08-01-2015 05:33 PM
Jeepin79
Wheels/Tires
08-20-2012 11:18 PM
bzb123
01-20-2012 01:41 PM
blockzilla
09-04-2011 10:05 PM
leohd
03-24-2009 09:29 AM
Quick Reply: Wheel fitment
