2002 ultra advice needed
Send the seat to Mean City Cycles for a customization. https://www.hdforums.com/forum/mean-city-cycles-94/
Maybe some street glide shocks too.
I have an 02 EGC with 45K miles. In light of how long my chain tensioner lasted, I'd at least pull off the cover & examine the chain tensioner. I replaced mine @ 30K & 42K, & I think the new design should last longer than 12K miles.
Does your 02 have the 88 engine or was it upgraded to a 95"? At 42K, I had a lifter go bad & as I pulled things apart, found that the old INA cam bearings were still in place, so I replaced them with Torringtons. If you want to go "that deep" into the side of the engine, you might want to consider that. If you do, add a "Latus spring" [It's actually made by Baisley High Performance in Portland, OR] on the oil pump to get better pressure at idle when warm.
The bottom line is that I'm [I]really happy[I] with my '02, & think you will be, too. If the price is right, you'll get a lot of value for the money.
