Where to get tire balancing?
Old 11-11-2009, 02:32 PM
heywood727's Avatar
heywood727
heywood727 is offline
Another Vote for Dyna Beads
Old 11-11-2009, 02:36 PM
Trailfndr's Avatar
Trailfndr
Trailfndr is offline
Originally Posted by EasternSP
I would think the dyna beads would sound like the infants rattle toys when starting or stopping.
SInce you useonly 1-2 ounces, and they are so micro small, there is no noise whatsoever They are ceramic, so that also cuts the sound. I'll never change another tire without them...
I am running them in my Ultra, and the wifes Deluxe, and both bikes run smoother down the road then they did with wieghts.
Nothing to installing them...simply remove the valve core, hook up a small hose to the stem, tip the bottle, and tap the stem till they all get in. ( a vibrating tool helps alot, I used an engraving tool...)
Just make sure that the tire is dry when installed...Water or grease inside the tire wilcause the beads to clump and not work properly.
Old 11-11-2009, 03:57 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,861 Likes on 2,426 Posts
Why is this a question? Get your tyres fitted by a professional tyre fitter who should balance them as a routine. Dyna beads are a sticking plaster!
Old 11-11-2009, 04:15 PM
Yachtman's Avatar
Yachtman
Yachtman is offline
Define this please?!
Old 11-12-2009, 12:00 AM
RexBuck's Avatar
RexBuck
RexBuck is offline
+1 Dyna Beads - I don't understand how they work but they do.
As for noise - if there is any noise from the beads, I doubt I could hear it above the pipes and all the other rattles and general noise of my bike.
Old 11-12-2009, 12:22 AM
mike5511's Avatar
mike5511
mike5511 is offline
Dyna beads sound like a good deal. The theory has been around for a while. I would like to use the product listed below, but it doesn't seem to me that it would work with the Dyna Beads. Anybody know for sure??
http://www.ride-on.com/prod_mot.asp
Old 11-12-2009, 03:42 AM
hoytheld's Avatar
hoytheld
hoytheld is offline
The good thing about Dyna-beads is...they are constantly balancing the tire....wheel weights are good...until you get 1 mile on the tire, then, in a sense, the tire will start to wear and the balancing is shot..... I have beads in the two bikes I own....makes it a lot easier on the wallet doing your own tire change and throwing in some beads...hell that saves at least $40-50 here!!
Dyna-Beads A+++++++++++++++++!!!
Old 11-12-2009, 06:33 AM
grbrown's Avatar
grbrown
grbrown is offline
We put a sticking plaster over a wound, but it doesn't heal the wound, just covers or hides it! Not a very good comparison I realise, but if tyres are balanced when fitted, they are balanced or healed. Installing dyna beads doesn't cure the problem at source, merely covers or masks it.
A desirable tyre 'accessory' is a tyre sealant, especially when travelling on that big trip of a lifetime. Beads wouldn't work in a sticky substance, so they fail again. They are no substitute for balancing the wheels the traditional way!
Old 11-12-2009, 06:45 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,823 Likes on 3,499 Posts
My indy balances my tires everytime...with a bubble balancer and i have never had any issues. He charges me $15 or $25 if they keep the tire.
Old 11-12-2009, 06:54 AM
Yachtman's Avatar
Yachtman
Yachtman is offline
grbrown,
Exellent explanation.
Thanks
Quick Reply: Where to get tire balancing?
